ProjeQtOr free project management software - [SOLVED] selecting project for display - ProjeQtOr
06 Jul 2018 10:53 #1 by NorbertD
hello
in the topline of the Screen i can select a Project, so that all Screens Show only the items of the selected Project (except the today Screen - unfortunately).
but all the users see all the Projects. that is not good, because i want to handle several Projects with different customers and the customers should not see the other Projects.
thanks
Greeting
Norbert
06 Jul 2018 11:20 #2 by AtomicStruct
Hi Norbert,
Try to play around with the access rights menus.
Since there are many ways to solve this, you need to put some time in it to find out the solution that works best for you.
06 Jul 2018 11:27 #3 by NorbertD
That is Not a Problem of Access rights for Menus, which Works Fine.
You See all the projects in the Selection List.
06 Jul 2018 11:41 #4 by babynus
YES IT IS !
NOT WHEN ACCESS RIGHTS ARE CORRECTLY DEFINED
Have a look at demo.
Try and connect an "manager" and then as "gestrionnaire" : you'll not see same projects.
So you have some configuration of rights that leads to visibility of all projects.
The following user(s) said Thank You: AtomicStruct
06 Jul 2018 12:41 #5 by NorbertD
yes i see the difference.
Login as a guest and you see other Projects than the Supervisor.
but what have i Change.
i have examined two Projects (SCHTROUMPF, gestion eco).
Supervisor has both Projects in the selection list, guest doesnt see SCHTROUMPF.
but what is the difference?
06 Jul 2018 13:06 #6 by babynus
You changed something on access rights that give visibility to "all items on all projects"
