ProjeQtOr free project management software - Problem to change rate of ressource in a pool - ProjeQtOr
21 Jun 2018 11:34 #1 by FGE
I add one ressource in pool A with 100% rate
If I want to change the rate to 60%, an error occurs because of use over than 100%
To bypass the problem, you have to change rate to 0%, save it and change rate to 60%
21 Jun 2018 12:40 #2 by alainforma
Good afternoon,
Anomaly confirmed.
Ticket 3438
The correction will be made in the next patch
21 Jun 2018 14:18 - 21 Jun 2018 14:19 #3 by babynus
Issue fixed.
Will be deployed with next patch.
Fix is to add 4 lines after line 65 in /model/ResourceTeamAffectation.php, this way (4 last lines) :
public function control(){
    $result="";
    if($this->idle==0){
      $idResource = $this->idResource;
      $rate = $this->rate;
      if($this->id){
        $teamAff = new ResourceTeamAffectation($this->id);
        $rate = $rate - $teamAff->rate;
Last edit: 21 Jun 2018 14:19 by babynus.
