ProjeQtOr free project management software - Restricting Cusomizations to a Project - ProjeQtOr
19 Nov 2011 23:19 #1 by harry2011
I would like to use Project'Or RIA for some of our projects but I need to customize for each project. Such customization should not effect other projects. How can I do it? gopi
20 Nov 2011 11:58 #2 by babynus
All depends what you really need to customise for each project.
Could you give precisions ?
Anyway, the best way to have all parameters specific to each project is to set one database per project...
20 Nov 2011 18:04 #3 by harry2011
Thank you for the prompt answer. I am not sure, but we will need to customize virtually all the parameters. Activity workflow and permissions. I think it will simpler for us to follow your advise and have different databases for each type of project. Can different data bases share users and team members? gopi
20 Nov 2011 18:23 #4 by babynus
No, you cannot "share" resources.
But it's easy to import data, for instance from a reference csv file.
(it will also be possible to export in V1.9)
Then just adapt capacity and / on affectation rate to be sure to reserve some shared reources for some projects.
Regards.
20 Nov 2011 19:11 #5 by harry2011
Thank you once again. I think we will do an experiment and see how that will work. I am embarassed that I could not find the online manual, even though in the tips and tricks section of forum it is mentioned. Can you advise how to get at the manual? gopi
20 Nov 2011 19:22 #6 by babynus
It' available :
- on each distribution, just hit [F1]
- here on the web site : Demo / Online Manual
- on the demo or track database, just hit [F1]
- on the download page (ppt format)
Regards.
