ProjeQtOr free project management software - Suggestion to add some clarification in help for Dependencies - ProjeQtOr
23 May 2018 10:44 #1 by NarayanAras
The help documentation states that ProjeQtor provides only FS-type dependency.
(Ref: en.wikipedia.org/wiki/Dependency_(project_management))
Then it proceeds to cover the other three types (SS, SF, FF).
For SS, it recommends a workaround of adding a milestones for both tasks.
While this is correct, in a normal project, usually there would be a predecessor task that serves the same purpose.
In that case there is no need for a milestone.
I think this needs to be pointed out.
The help should also point out that without a milestone or predecessor task, the activities would typically launch in "ASAP" mode (delayed only the availability of their respective resources), rather than being launched together.
23 May 2018 23:41 #2 by babynus
Actual user manual is based on V6.3.
Hope we'll have time to improve it...
28 May 2018 07:24 #3 by NarayanAras
No, the limitations are still the same even now.
I suggested extra notes, to clarify the help documentation.
28 May 2018 09:24 #4 by babynus
There won't be any visible change until we publish new version.
28 May 2018 09:51 #5 by NarayanAras
Time to create page: 0.078 seconds
