Is it possible, when i have two projects, to merge them in one project and if so, is it possible to also merge imputations from previous projects on the new one?
You can set one as sub-project of the other or move both as sub-project of same parent.
Parent will automatically consolidate work for its sub-projects.
Thanks for your answer !
Also i've got one more question about imputations. Is it possible to import them, in don't see a field for this in the "import data" section ?
