ProjeQtOr free project management software - Meeting and "Following tasks could not be completely planned" - ProjeQtOr
12 Mar 2018 08:26 #1 by jmoutel
I have a problem with meetings. When I assign a resource to a meeting and compute an updated planning, I often get the message "Following tasks could not be completely planned" and I see that the resource doen't have enough free time for the meeting.
Indeed, there is planned work on another activity.
I thought meetings took precedence over other activities so I don't understand why the other activity is not rescheduled later.
12 Mar 2018 09:19 #2 by babynus
Yes, meeting take precedence.
But if resource is working on "another" project, you'll have to calculate both projects at same time.
12 Mar 2018 09:45 #3 by jmoutel
The conflicting activity (planning mode is ASAP) is in the same project but not the same subproject.
When rescheduling, I tried to select the root project + all the subprojects + all the other projects where the resource is involved with no luck.
I tried to lower the priority of the conflicting activity but then the planned time goes to another activity, not the meeting.
12 Mar 2018 10:04 #4 by babynus
What version of ProjeQtOr are you using ?
We fixed an issue on V6.5.6 (#3241) leading to incomplete planning of meeting depending on start time and work.
12 Mar 2018 10:07 #5 by jmoutel
We are using V6.5.2.
We will update to V6.5.6 and then I'll get back to you.
Thank you
12 Mar 2018 10:24 #6 by babynus
NB : V6.5.7 has just been deployed ;)
