ProjeQtOr free project management software - [SOLVED] ScreenCustomization 5.1 : Milestone field "reference" always mandatory - ProjeQtOr
26 Feb 2018 17:08 #1 by ACTAJPi
When i use the plugin ScreenCustomization, i can't change the attribute "required" on the field "reference" of the object "Milestone".
The field is always required when i pass a milestone to a "done" status, even if the "required" checkbox is not checked.
I use Projeqtor 6.5.5, on PHP 5.3.6
Thank you
26 Feb 2018 17:28 #2 by babynus
Isn't it checked depending on status ?
27 Feb 2018 08:09 #3 by ACTAJPi
No, it is not checked in all cases (status, type, profil, or general field settings)
27 Feb 2018 08:14 - 27 Feb 2018 08:15 #4 by ACTAJPi
I made a mistake when i have write the post. The field which is always required is the field "result", not "reference"
thank you
Last edit: 27 Feb 2018 08:15 by ACTAJPi.
27 Feb 2018 09:23 #5 by babynus
This is more clear :woohoo:
This is a customization defined on type... B)
On milestones types, uncheck "result ... mandatory on done status"
27 Feb 2018 10:15 #6 by ACTAJPi
