ProjeQtOr free project management software - Issue on first installation : installation process fails - ProjeQtOr
23 Feb 2018 19:24 #1 by gsilber
I'm trying to setup projeqtor version 6.5.6, on XAMPP.
The installation/initialization process works about 15 minutes and fails with following error :
2018-02-23 18:54:12.187 ===== TRACE ===== REWRITE PARAMTERS.PHP FILE = END ======================
2018-02-23 18:54:12.258 ***** ERROR ***** [] ERROR *****
2018-02-23 18:54:12.264 ***** ERROR ***** [] on file 'C:\xampp\htdocs\sos\db\maintenance.php' at line (266)
2018-02-23 18:54:12.269 ***** ERROR ***** [] cause = count(): Parameter must be an array or an object that implements Countable
Best Regards,
Guy Silberzahn
23 Feb 2018 19:31 #2 by babynus
Which version of PHP ?
23 Feb 2018 19:38 #3 by gsilber
23 Feb 2018 19:44 #4 by babynus
ProjeQtOr is not tested against PHP7.2, and I'm afraid it is not compatible.
Try with PHP 7.1
The following user(s) said Thank You: gsilber
24 Feb 2018 16:48 - 24 Feb 2018 16:48 #5 by gsilber
I downgrad Xampp to previous version with PHP 7.1.14.
Installation run without error and is completed.
now i can test ProjeQtOr and quite sure will use it soon.
thank you for your very quick answers and help
Guy Silberzahn
Last edit: 24 Feb 2018 16:48 by gsilber.
