ProjeQtOr free project management software - Hide a project - ProjeQtOr
Hide a project
23 Feb 2018 12:16 #1 by Yannobi
Hide a project was created by Yannobi
I have some projects using a specific project type (named "internal"). For the exemple, let say "PROJECT A"
This PROJECT A is allocated to the "project manager" and assigned to some "project members" but i don't want this specific project to be viewed by the "project members". It's the "project manager" that do the real work allocation of all members.
So i try to hide PROJECT A using restrictions type applied to the "project member" profil : I select all types of project except "internal"
The global parameter "type restriction on project” is set to “Yes”
But "project member" still view PROJECT A
What do i do wrong ?
Thank you for your help.
Yann
23 Feb 2018 19:43 #2 by babynus
Replied by babynus on topic Hide a project
Restriction on type only restrict list of types that can be created, not view.
You just have to allowate members with profile with correct access right.
Have a look at user manual.
