ProjeQtOr free project management software - Actions are not copy with the project (V6.5.5 & V6.5.6) - ProjeQtOr
18 Feb 2018 19:39 #1 by xb
Thank you for the realy good job you doing ! PorjeQtor is a very good tools.
Is it normal that actions are not copy with the project when the project is copy with all check box actived ?
Activitys and sub projects are copy but not actions.
Thank you
Je tiens à vous remercier pour l’excellent travail que vous faites. PorjeQtor est un très bel outils.
Est-il normal que les actions ne soient pas copiées lorsqu'un projet est copiée avec toutes les cases à cochées activées lors de la copie ?
Les activités et les sous-projets sont bien copiées, mais pas les actions.
Merci
21 Feb 2018 10:18 - 21 Feb 2018 10:18 #2 by babynus
Yes, it is normal to not copy actions when copyong project.
Idea when copying project is to be able to copy its "structure", meaning thje Work Breakdown Structure.
This includes only the "planable" items.
There are 2 options, to copy :
1) main plannable items (activities and milstones)
2) other planable items (meetings, test sessions)
But not plannable items are not copied : actions, questions, decisions, deliveries, risks, ...
If you really need to copy Actions from one project to naothere, here is a trick :
=> export actions in CSV format (from list of actions)
=> change project in csv file and remove id : this last point is very important to create copies and not change existing; best is to export csv without id..
=> re-import file : it will generate copies
IT'S A KIND OF MAGIC :woohoo:
Last edit: 21 Feb 2018 10:18 by babynus.
