ProjeQtOr free project management software - [SOLVED] Product visibility limitation to project - ProjeQtOr
06 Feb 2018 14:06 #1 by ancm
Hello everybody!
I have the following question; Is it possible to limit the product list visibility to a project, just like with the documents? Documents are visible per project. (I am running 6.5.4)
Any reaction much appreciated.
Kind regards,
Mike
06 Feb 2018 16:39 #2 by babynus
In combos, list is limited to products having a version linked to projects the resource is allocated to.
But this restriction is not applied on Products screen list.
