ProjeQtOr free project management software - [SOLVED] LDAP Filter not upated - ProjeQtOr
05 Feb 2018 11:37 #1 by pleky
LDAP Filter not upated was created by pleky
I'm trying to setup LDAP connection to an AD.
I've made some mistake like forgetting to install php-ldap (BTW it is with a - and not a _ like in the debug message)
Now I've got a "last issue" : I've corrected the filter string thanks to the forum, but on the log I still have a message like this one :
authenticate - Filter error : ldap_search returned no result for filter uid=%samaccountname%
I wasn't able to find this filter (even in parameters.php), and on the site global paramters I have the correct filter.
I guess the info is in the DB, is there a cache or something else to refresh ?
Thanks,
05 Feb 2018 11:47 #2 by babynus
Replied by babynus on topic LDAP Filter not upated
Filter uid=%samaccountname%
It may be uid=%USERNAME%
or samaccountname=%USERNAME%
The %USERNAME% will be replaced with current login user name.
05 Feb 2018 12:14 #3 by pleky
Replied by pleky on topic LDAP Filter not upated
Hello Babynus,
Thanks for your quick feedback.
That's what I've done, it is on the interface setup and in the mysql DB =
sAMAccountName=%USERNAME%
But when I read the log file, I still have an old bad value :
authenticate - Filter error : ldap_search returned no result for filter uid=%samaccountname%)
And I'm not able to identify where uid=... comes from...
Any idea ?
05 Feb 2018 12:46 #4 by babynus
Check if you have same aprameter define in parameters.php file : value in the file overwrites db value.
05 Feb 2018 12:53 #5 by pleky
I've tried to manually add the setting in parameters.php, but it looks like Projeqtor wasn't happy with this : error 500.
I've found that if I use private mode or another browser I no longer have the issue.
Do you know if the filter is pushed to the browser or if apache or PHP has a cache per session ?
Thanks,
05 Feb 2018 12:59 #6 by pleky
Ok, I've found the issue :
there were some php session things remaining with the old filter.
I've check in /var/lib/php/session
and found two files including "uid="
I've deleted both, and now I can log :)
Thanks for your help, I can move to the next step
