ProjeQtOr free project management software - Problem with hierarchy on PROJECT VIEW - ProjeQtOr
31 Jan 2018 11:23 - 31 Jan 2018 11:30 #1 by kobetsu
PQ: 6.5.3
We still observate incorrect hierarchy of items in Project View. Acivitives are new, created recently but after move (or other operations which hard for me to idenitify) make hierarch incorrect:
WBS of first item on picture (couting from top): 14.5.2.1.1.1.2.6.40
second (this one with incorrect hierarchy): 14.5.2.1.1.1.2.6.40
third: 14.5.2.1.1.1.2.6.41
Seems I have 2 items with the same WBS
When I use commands:
and then:
in context of activity (which has problem of hierarchy - second on picture).
In result:
WBS of first item on picture (from top) was changed to: 14.5.2.1.1.1.2.6.39
second stay: 14.5.2.1.1.1.2.6.40
third: stay 14.5.2.1.1.1.2.6.41
IMHO there is gap in functionalities allowing to make mess in WBS.
Last edit: 31 Jan 2018 11:30 by kobetsu.
01 Feb 2018 21:53 #2 by babynus
thnaks for reporting the issue.
Difficult to investigate without so few information.
Could you retreive and post here history for concerned activities ?
02 Feb 2018 09:51 #3 by kobetsu
Base on this picture again:
Activities from top have IDs:
1. 1442
2. 2098
3. 2079
I did not find any other way to export history than make pictures, so...
History of 1442 is (not complete... it is too long):
History of 2098 is:
part1:
part2:
History of 2079:
About problem... I dare to propose to add additional log info when such cases were detected or DB constrains blocking such cases.
02 Feb 2018 23:09 #4 by babynus
Thanks for traces.
It seems that WBS unnecessarily increses (and so may update to duplicate value)
I opened ticket #3231 to investigate.
05 Apr 2018 16:41 #5 by kobetsu
How can I navigate to issue of given numer (in this case 3231) to check state of it ?
06 Apr 2018 19:52 #6 by babynus
Go to track instance track.projeqtor.org/ and search for Ticket #3231
(it is delevered in V6.5.5)
The following user(s) said Thank You: kobetsu
Time to create page: 0.077 seconds
