ProjeQtOr free project management software - Project associate with a Subproject - ProjeQtOr
09 Jan 2018 10:01 #1 by sogeti
How to remove the assosiation of a project to a subproject ?
Thank you
Best Regards,
09 Jan 2018 10:04 #2 by babynus
On sub-project, remove value for field "is sub-project of".
09 Jan 2018 10:35 #3 by sogeti
Thank you for you response.
But it generates an error.
Best Regards,
09 Jan 2018 11:28 #4 by babynus
Issue recorded as Ticket #3181
09 Jan 2018 11:56 #5 by babynus
Fix is to replace line 1398 in /model/persistence/SqlElement.php from
if ($col_name == 'idProject') {
to
if ($col_name == 'idProject' and get_class($this)!='Project') {
Fix will be deployed in next patch.
The following user(s) said Thank You: sogeti
09 Jan 2018 15:19 #6 by sogeti
I am in v 6.4.4 and in the SqlElement.php file, line 1398 is :
if (Sql::isPgsql ())) {
Can you find another solution ?
Best Regards,
