ProjeQtOr free project management software - probleme installation - ProjeQtOr
04 Jan 2018 12:07 #1 by sao
probleme installation was created by sao
When installing ProjeQtor, I encountered the following problem:
SQLSTATE[HY000] [2002] php_network_getaddresses;;getaddrinfo failed; Name or service not known dsn = mysql:host=.......dsi.univ-paris5.fr ; port=3306
Thank you pars advance
04 Jan 2018 12:15 #2 by babynus
Replied by babynus on topic probleme installation
Configuration of access to database is not correct.
04 Jan 2018 12:36 #3 by sao
Replied by sao on topic probleme installation
and yet I informed the fields
04 Jan 2018 13:15 #4 by sao
Here is my configuration:
- Database user to connect : xxxxxxxx
- Database password for user : yyyyyyyyyyyy
- Database schema name : projeqtor
- Name to be displayed : ProjeQtOr
- Allow login from Ldap : true
- Ldap Base DN : dc=xxxxxxxxxxxxx,dc=fr
- Ldap Host address : ldap.parisxxxxxxxxxx.fr
- Ldap Port : 389
- Ldap version : 3
- Ldap Search User : cn=xxxxxxxxxx, ou=yyyyyyyyyy, dc=xxxxxxxxxxxx, dc=fr
- LDAP Search User Password : xxxxxxxx
- Ldap filter : uid=%USERNAME%
- SMTP Server : smtp.parisxxxxxxxx.fr
- SMTP Port : 25
- Default password for initialization : projeqtor
- Min length for password : 5
04 Jan 2018 13:39 #5 by babynus
Database host is missing ...
Are you sure a MySql instance is running on this host ?
