ProjeQtOr free project management software - [SOLVED] WBS Incrementation problem - ProjeQtOr
27 Dec 2017 14:29 #1 by sogeti
Following an import, WBS id remains at 1000, incrementation is no longer done.
How to fix problem?
Thank You
Best Regards,
27 Dec 2017 14:57 #2 by babynus
Replied by babynus on topic WBS Incrementation problem
Move task (for instance change parent), then back to correct place.
The following user(s) said Thank You: sogeti
