ProjeQtOr free project management software - Foreign columns inherited from parent project - ProjeQtOr
08 Dec 2017 12:12 #1 by pierre.martins
Let say I defined 2 project typologies A and B (Meaning I have diffèrent custom Colum for A and B)
I have an instance of A typology => Project 1
I have 2 instances of B => Project 11 and Project 12
Project 11 and 12 are child Projects of Project 1
- Is it possible to display information from the colums inherited from Project 1 when reviewing Project 11 and 12 ?
To be clearer Project 1 would be considered as a Metaproject with specific Managers and Sponsors.
I would like to know if when reviewing child projects of this meta project, I could inherit and see those pieces of informations either in the screens and in the reports ?
Best regards,
Pierre Martins
12 Dec 2017 09:27 #2 by babynus
Yes and No.
In fact, when you define custom visibility on project type, it is not inherited from parent, only from its own type.
But in your case you may set visibility depending on User Profile. Then some profiles may see columns as others may not.
