ProjeQtOr free project management software - [SOLVED] Problem to update activities - ProjeQtOr
24 Nov 2017 10:24 - 24 Nov 2017 10:26 #1 by QuentinB
Sometimes, planned end date is set before the planned start date, which prevent any further update on the concerned activity.
I'm currently using v6.2.5.
Here is a step by step method to generate this bug:
- Create an activity (just set the name, no date). It will appears on the current day (date D) on the planning.
- Run planning calculation a day before (D-1). Planned start and end date will be set to D-1.
- Update the field "handle" on the activity and set it on current date (date D).
- Run again a planning calculation
From here, you got an activity with a start date > end date which cause the bug.
Quentin.
How this can be fixed on the interface ? The only known possibility (to me) is to update the field in the database.
Last edit: 24 Nov 2017 10:26 by QuentinB.
24 Nov 2017 11:00 #2 by babynus
This issue is fixed on V6.4.4
24 Nov 2017 11:54 #3 by QuentinB
I followed the tutorial to update projeQtor version but the bug is still present.
When I logged in with admin account, i get the pop up with the 6.4.4 update notification, but I still read ProjeQtor 6.2.5 on the bottom right.
Did I missed something ?
Quentin.
24 Nov 2017 12:06 #4 by babynus
Sure !
Please post log file.
24 Nov 2017 13:44 #5 by QuentinB
Ok my bad, I haven't updated the right directory.
Now in 6.4.4, the bug is still alive (still possible to get a start date > end date) but the Activity can be updated.
Thanks !
Quentin.
