ProjeQtOr free project management software - Problem with dependent component list - ProjeQtOr
09 Nov 2017 14:37 #1 by kobetsu
I have defined component version and list of subcomponent versions used by it.
I can add/remove subcomponent version freely and this is quite fast.
but when I try to use edit button:
or "auto update":
process is very long... as long as server returns error:
Second point is low priority however enoying... as you see, no most of themes button of auto-update is not visible (but working):
09 Nov 2017 15:01 #2 by krowry
Hello ,
I can"t reproduce your anomaly.
- Can you give us log file please ?
For the second point , effectively , missing the icon . Anomaly #3079 recorded
09 Nov 2017 15:07 #3 by kobetsu
Here is the log:
File Attachment:
File Name: log.txt
File Size:17 KB
09 Nov 2017 15:36 #4 by krowry
Ok , i found an error with Language ...
Do you have the global parameters "Display language in Product/Component (Version) :" in "YES" ?
09 Nov 2017 15:46 #5 by kobetsu
Yes, we have this parameter set to "YES"
09 Nov 2017 15:51 - 09 Nov 2017 15:51 #6 by krowry
Try to set the parameters to "NO" and retry your test case
Last edit: 09 Nov 2017 15:51 by krowry.
