ProjeQtOr free project management software - Problem with left menu - ProjeQtOr
27 Oct 2017 08:10 #1 by kobetsu
Look at the picture:
all looks nice but then I hide menu by button "Hide menu" I have:
As you see menu "Incomes" starts to be divided into 2 lines but real problem is you cannot click here:
becasue "Incomes" link catch mouse event.
Because of this trivial problem people does not hide menu but move splitter of menu max to the left.
27 Oct 2017 09:56 #2 by babynus
Replied by babynus on topic Problem with left menu
Cannot reproduce.
With same configuration, all works fine :
I guess you changed something in table "menu", because you should see the "financial" level that does not appear on your side.
27 Oct 2017 17:33 #3 by kobetsu
Replied by kobetsu on topic Problem with left menu
How can I customize look of left menu ? Is there any UI for this or only plugin/code modification ?
27 Oct 2017 19:04 #4 by babynus
No, there is not.
Only restriction through "Acces to screen" form.
31 Oct 2017 10:38 #5 by kobetsu
So, iI solve this by turn off access to "Quotation" form but I think there is still bug in Projeqtor - there is possibility to define customization in this way (as I had) and in this case menu is working incorrectly.
31 Oct 2017 12:47 #6 by babynus
Customization has abslutely no effet (or at least should have no effect) on Menu.
Please describe use case step by step, so that we can analyse if it is an issue.
