ProjeQtOr free project management software - Problem with fields Priority and Progress - Page 2 - ProjeQtOr
13 Apr 2018 07:07 #7 by kobetsu
Thanks, solution works perfectly.
By the way, seems on 7.0.2 changing order of columns (at least on Activity view) is no longer working.
Additionally last right column (if it is rightside text justified) is not visible becasue it is covered by scroll bar.
13 Apr 2018 09:26 #8 by babynus
Cannot reproduce.
It's working fine on Chrome, FF, IE11 and Edge (I just tested)
Yes, the component is working this way, and has always worked this way. If it was not the case, headers would not be aligned with columns.
That's why we place "idle" field on last column, as it is centered and so visible.
Avoid putting numbers on right most field.
