ProjeQtOr free project management software - Suppress rich text format on project description field - ProjeQtOr
10 Oct 2017 20:14 #1 by ade
I generate powerpoint report, and i use the content of the project description.
All users are able to put complex text format (such bold, italic ...), and such format is not supported on powerPoint slide generation.
Is there a way to allow only plain text in the project description ? It means removing all text buttons and allow only plain text.
Thx for your answer.
11 Oct 2017 09:10 #2 by krowry
Hello ,
You can change the "editor for rich text" and use the editor "Plain text editor".
User parameters --> graphic interface behaviour ---> editor for rich text --> plain text editor
The following user(s) said Thank You: ade
