ProjeQtOr free project management software - [SOLVED] reset default calendar to default values - ProjeQtOr
15 Sep 2017 15:22 #1 by ancm
Hi All,
I cannot seem to find a way to reset the default calendar to it's default setting. I have changed some days in this calendar earlier but cannot change the state when I select the days.
Help is very much appreciated.
Regs,
mike
15 Sep 2017 15:56 #2 by babynus
I don't understand how you can get Mondays with red color...
Try and reset the table calendar.
Something like
DELETE FROM calendar WHERE idCalendarDefinition=1 AND year=2017;
18 Sep 2017 10:09 #3 by ancm
babynus wrote: I don't understand how you can get Mondays with red color...
Me neither.....
Something like
I will try this.
Thanks for your reply.
21 Sep 2017 09:44 #4 by ancm
The reset of the default calendar did the trick! Thanks for your reply and suggestion.
Mike
