ProjeQtOr free project management software - General Usage - ProjeQtOr
General Usage
06 Sep 2017 06:58 #1 by YehiaH
General Usage was created by YehiaH
I am trying to use Projeqtor for some project management / engineering projects mainly. I have checked the solution you offered and I have a couple of questions.
1- I'm trying to check for a manual on how to use the platform. It seems I cannot find anything beside the manual provided officially on the site- I believe this question was asked before and the answer was negative
2- I have a project usually, which have deliverables linked to certain milestones. Every project has different deliverables and different milestones. Each milestone has a weight to keep track of progress.
My main concern is to track progress on a given date based on the date of completeness of each milestones of each deliverable. Is this possible in Projeqtor?
3- Is there anywhere in the platform where I can upload already existent excel sheet that has projects details, dates, milestones and deliverables and proceed with the progress tracking from Projeqtor?
4- Is there any possibility to customize reports and charts produced?
06 Sep 2017 08:16 #2 by babynus
Replied by babynus on topic General Usage
No, no other manual than included user manual.
Think of F1 key on a screen : it will open manual at corresponding page
Also on manual, click on PROJEQTOR icon on top left will open table on content : there have a look at "concepts"
A milestone cannot have a weight : it has no duration and no workload. DEliverable can have weight, but it does not give progress of project.
Progress of project os work driven : activities give progress, and their weight is the assigned work.
You can upload items through import feature.
But you'll have to import by item types : projects, then activities, then milestones.
Not as of today, not without coding.
