ProjeQtOr free project management software - Project Expense - ProjeQtOr
Project Expense
28 Aug 2017 17:00 #1 by f.arnaud@pahntos.com
In my project calculation, only one line is linked with the left expense.
I mean, I have 3 lines for project expense, but only the first line "Provision Garantie" is refreshed in left expense project.
I don't understand why, the left expense is not the difference between, assigned expense and real expense.
If I change the value id 163 in project expense, the value in left expense for projet will be refreshed with the value of id 163.
Do you have an idea with data in the file joined ?
28 Aug 2017 22:39 #2 by projeqtor80
Replied by projeqtor80 on topic Project Expense
i am a beginner of projeqtor.
but i wonder if reports in "follow-up -> reports -> costs" that you can see, seems to be ok and then refreshed ?
The following user(s) said Thank You: f.arnaud@pahntos.com
29 Aug 2017 16:30 #3 by f.arnaud@pahntos.com
Thank you for your answer.
I have fixed the problem ! I have created new expense with the correct amount, andthe left expense was refreshed with the correct amount in my project (Sum of different project line expense).
29 Aug 2017 17:58 #4 by projeqtor80
good news !
Create a new expense triggered refresh of amount of project.
However, if you modify again a value of expense, only one line of expense, the amount of project refresh correctly ?
30 Aug 2017 07:37 #5 by f.arnaud@pahntos.com
I did it, and it works fine !
I have modified one of new lines, and the total amount was updated.
30 Aug 2017 11:01 #6 by projeqtor80
thanks for your feedback.
this could be useful for projeqtor's users. I don't use this part but soon certainly.
Have a nice day.
