ProjeQtOr free project management software - First connexion failed with admin parameters - ProjeQtOr
16 Aug 2017 11:38 #1 by christ10
Morning, when i want to connect the first time with admin/admin parameters, i have " paramètres de connexion incorrects". when i see my log file is presented like this:
2017-08-16 09:45:00.052 ===== TRACE ===== Parameter $enforceUTF8 added
2017-08-16 09:45:00.088 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'cmgemhnm_gesprofoder.user' doesn't exist
2017-08-16 09:45:00.088 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-08-16 09:45:00.088 ***** ERROR ***** Strack trace :
2017-08-16 09:45:00.088 ***** ERROR ***** #0 Sql->query called at [/home/cmgemhnm/public_html/model/persistence/SqlElement.php:1840]
2017-08-16 09:45:00.088 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/cmgemhnm/public_html/tool/loginCheck.php:67]
2017-08-16 09:45:00.123 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'cmgemhnm_gesprofoder.user' doesn't exist
2017-08-16 09:45:00.123 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-08-16 09:45:00.123 ***** ERROR ***** Strack trace :
2017-08-16 09:45:00.123 ***** ERROR ***** #0 Sql->query called at [/home/cmgemhnm/public_html/model/persistence/SqlElement.php:1840]
2017-08-16 09:45:00.123 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/cmgemhnm/public_html/tool/loginCheck.php:67]
2017-08-16 09:45:00.158 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'cmgemhnm_gesprofoder.user' doesn't exist
2017-08-16 09:45:00.158 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-08-16 09:45:00.158 ***** ERROR ***** Strack trace :
2017-08-16 09:45:00.158 ***** ERROR ***** #0 Sql->query called at [/home/cmgemhnm/public_html/model/persistence/SqlElement.php:1840]
2017-08-16 09:45:00.158 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/cmgemhnm/public_html/tool/loginCheck.php:67]
2017-08-16 09:47:58.023 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'cmgemhnm_gesprofoder.user' doesn't exist
2017-08-16 09:47:58.023 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-08-16 09:47:58.023 ***** ERROR ***** Strack trace :
2017-08-16 09:47:58.023 ***** ERROR ***** #0 Sql->query called at [/home/cmgemhnm/public_html/model/persistence/SqlElement.php:1840]
2017-08-16 09:47:58.023 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/cmgemhnm/public_html/tool/loginCheck.php:67]
2017-08-16 09:47:58.023 ===== TRACE ===== Login error for user 'admin'
2017-08-16 09:52:50.478 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'cmgemhnm_gesprofoder.user' doesn't exist
2017-08-16 09:52:50.478 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2017-08-16 09:52:50.478 ***** ERROR ***** Strack trace :
2017-08-16 09:52:50.478 ***** ERROR ***** #0 Sql->query called at [/home/cmgemhnm/public_html/model/persistence/SqlElement.php:1840]
2017-08-16 09:52:50.478 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [/home/cmgemhnm/public_html/tool/loginCheck.php:67]
2017-08-16 09:52:50.478 ===== TRACE ===== Login error for user 'admin'
Pleased help me
16 Aug 2017 11:50 #2 by babynus
Can you post begining of log file, with all database upgrade process ?
16 Aug 2017 12:21 #3 by christ10
Yes Babynus. this is my log file in attachment.
File Attachment:
File Name: projeqtor_...0816.log
File Size:125 KB
16 Aug 2017 17:57 #4 by babynus
Scripts comes to an end during update for V4.4.0 (setup applies incremental updates).
So maybe you reached some timeout.
Try and increase max_execution_time in php.ini (try value 600 for 5mn)
Or try and install each major version (1.0.0, then overwrite with 2.0.0, and so on to latest)
17 Aug 2017 17:58 #5 by christ10
Hi Babynus. I've increased max_execution_time to 600 and it is not resolve the problem. I've try to install 1.0.0 version, 2.0.0, 3.0.0, 4.0.0 and it makes the same problem. Thks
18 Aug 2017 17:13 #6 by babynus
Can you post log files for each install ?
