ProjeQtOr free project management software - [SOLVED] installation ovh - Page 2 - ProjeQtOr
24 Jul 2017 16:51 #7 by pit
Replied by pit on topic installation ovh
Good evening,
I put my 4 values in the right areas that you indicated to me. Everything is green except a line that appears at the bottom:
Dsn = mysql: host = allianceumallian.mysql.db; port = 3306 "SQLSTATE [28000] [1045] Access denied for user 'allianceumallian'@'10.0.86.10'
I am at ovh in shared server
An idea to help me - thank you very much.
Bonsoir,
J'ai bien rentré mes 4 valeurs dans les bonnes zones que tu m'as indiqué. tout est au vert sauf une ligne qui s'affiche tout en bas :
"SQLSTATE[28000] [1045] Access denied for user 'allianceumallian'@'10.0.86.10' (using password: YES) dsn = mysql:host=allianceumallian.mysql.db;port=3306"
je suis chez ovh en serveur mutualisé
une idée pour m'aider ?? - merci beaucoup.
24 Jul 2017 17:14 #8 by babynus
Replied by babynus on topic installation ovh
Try and ask you web hoster how you should configure access
You can show your connection string as an example (dsn = mysql:host=allianceumallian.mysql.db;port=3306)
Maybe database host is "localhost"
24 Jul 2017 17:29 #9 by pit
Ok - installation completed. A small (very small) error on the password ... thanks for your help.
