ProjeQtOr free project management software - Tickets -> Products : how a user can add a product to a ticket - ProjeQtOr
12 Jul 2017 14:20 - 13 Jul 2017 10:34 #1 by Kitcat711
I created a product linked to my project:
My "pilote" profile has a "manager" rights profile (not changed from the installation of projeQtor).
When connected with the user "pilote" and trying to add a product, nothing shows:
The field is empty and no "magnify" icon is shown.
I tried to modify every possible access right I found, but was unable to find a way to change it.
1) How do I allow a user to set up a product?
2) Do I have a way to define a default value?
3) Same question for any field on the tickeMain
Thank you for your patience.
Last edit: 13 Jul 2017 10:34 by Kitcat711. Reason: Wrong screen shot
13 Jul 2017 00:18 #2 by babynus
Tis icon is displayed depending on "specific access" definition.
Give access rights is habilitation section
No, not with standard version.
With the screen customization plugin, you could set it as required, and first in the list will automatically become the defaut one, or you can set defautl value with the plugin.
Same answer ;)
13 Jul 2017 10:46 #3 by Kitcat711
I tried in the:
- "Access rights"-> "specific access": but found no section that would "logically" fit with the product.
- "Access rights"-> "profile": went to "restrict types" and check/unchecked the "product" section => no change.
Question : By the way: the "restrict types" functionality is not clear => the "title" expresses that checking a box will FORBID the access, but the sentence on the pop up "when restricting types, only these types will be displayed for users of this profile" expresses the opposite: "checking a box will GRANT the access" so I am not sure of what it does and I tried both. :)
Still having the same screen (updated the first ticket that was not showing the right screenshot).
Kitcat711
PS: Still discovering the product, not ready to buy the plugin yet (are the updates included in the price / license ?)
Thanks again
15 Jul 2017 09:47 #4 by babynus
"Access Rights" > "Specific access" > Section "Display specific buttons" > "Parameter display of combo detail button"
"Access Rights" > "Acces to forms" > Section "Configuration Management" >, check line "Product" for correspondng profiles
"Access Rights" > "Acces to data (not project dependant)" > first section > Line "Product" > select "write" for corresponding profiles
I cannot see the term FORBID. It is alway subject of RESTRICTION.
What may be not clear, is that when no item is checked, no restriction is pallied. When at least one is checked, only checked ones are visible.
Yes, of course.
The following user(s) said Thank You: Kitcat711
15 Jul 2017 10:43 #5 by Kitcat711
You are right, the word FORBID is not shown.
Nevertheless, To RESTRICT is to FORBID some access.
Your second sentence is true: the concern is that the behavior change depending of "at least one is checked".
I believe that could be improved by:
- giving a proper title: in fact this part about AUTHORIZATION and not RESTrICTION, it shows what is allowed (when checked).
- not changing the meaning depending of the "at least one is checked" - which is so far still not clear, does this rule apply line by line or for the whole screen - by default, if I understood well, all checkbox are checked (everything is authorized)
#my2cents :)
15 Jul 2017 23:31 #6 by babynus
No, restrict is not forbit, it is the opposite (allow only).
If you have A and B, restrict to A allows A and not B, forbid A allows B and not A
