ProjeQtOr free project management software - Low speed when loading. - ProjeQtOr
10 Jul 2017 07:33 #1 by vanlele
My projeqtor is running on local Xampp.
The total activities we created is about 9,000 item. And i see the sofware start to run low.
It need 15 seconds to load info of activities when i click, the same for other request.
My server PC i is core i5, ram 16Gb.
Can you tell me why it too low speed please, how to speed up?
10 Jul 2017 08:52 #2 by babynus
Replied by babynus on topic Low speed when loading.
Difficult to investigate with so little information.
First, whan you say "access to activities" do you mean get the list or get the detail of one activity ?
10 Jul 2017 09:17 #3 by vanlele
Replied by vanlele on topic Low speed when loading.
The same for listing activities and show info.
Even when i update activites info, it need about 8 seconds.
10 Jul 2017 20:29 #4 by babynus
I can confirm this is not normal.
For instance you can test perfs.projeqtor.org, with about 10000 activities.
Listing all activities is less than 3 seconds.
Getting detail for 1 activity is abot 1 second.
Check log file for errors of too verbuous logging.
You can possibly check log files for mysql and activite the "long query logging" to check which queries are long.
Check your CPU, and HDD accees.
Maybe it's just configuration of mysql allowing too small cache...
It's difficult to help more without investigating on the machine.
11 Jul 2017 04:06 #5 by vanlele
I have found a lot long query like this:
2017-07-11 08:25:40.642
DEBUG
5.208813;select * from history where (refType, refId) in ( ('x',0), ('Activity', 8855), ('ActivityPlanningElement', 9975)) order by operationDate desc, id asc
Can you help me to fix it please?
11 Jul 2017 06:50 - 11 Jul 2017 06:50 #6 by vanlele
Dear Babynus
In attachment is log file, its record only time for update name of activites.
To load activites info now its just take 4 seconds. Then i change name of activities and save, it took 50 seconds.
Please help.
Last edit: 11 Jul 2017 06:50 by vanlele.
