- Thank you received: 1
I think we leave on parallel worlds.But looking at real organization, a resource is NEVER allowed to take such unilateral decisions!
At best, this can be a request from him to the PM, to let him have more time. That too, only if the PM agrees.
Most likely, the PM will insist on closing the task on time.
MAybe, in some later version.But ProjeQtor does not have a feature to automatically extend their effort when the task gets extended.
There should be a way to do this.
MS Office has long been duration driven.... so yes, it is one of the way is works.In fact, MS Office allows the PM to define the duration, and then it converts the duration into effort.
Something similar should be done here.
