ProjeQtOr free project management software - Gantt bars problem - ProjeQtOr
Gantt bars problem
13 Jun 2017 17:29 #1 by hectordufau
Dear friend,
I have some troubles with Planning activities in past dates. The first activity started in June, 5th, with 3 days of duration, the second started after, in June, 8th, with 10 days of duration, and the last will start in June 23th, with 3 days of duration. These activities have precedents, one another (except the first).
Initially, the bars was ok with their lenght and date position. But after changed task status to "attributed", giving to it a responsible, and after changing task progress planning to "regular between dates", my gantt task bars become unconfigured, even with correct planned dates. (see attached pictures)
How to I to do solve (or avoid) this problem? I need to register work allocation time, to show task and project progress by calculation, even creating a project with tasks with started past dates.
Please, someone has a suggestion?
Hector Dufau
19 Jun 2017 16:29 #2 by babynus
Replied by babynus on topic Gantt bars problem
About first task, it is finished (no left work) so start date is first day of real work allocation, and end date is last day of real work allocation.
About third task, it has no assigned work. So date are managed through status.
You set it into a status "in progress", (the handled tag is checked) so start date is considered as real start date.
And constraint to end on june 27th is correct.
