ProjeQtOr free project management software - [SOLVED] Linked element not working for Ver 6.0.0 - ProjeQtOr
13 Jun 2017 16:16 #1 by Optimist
I am working on V6.0.0 of ProjeQtor. The linked element in this ver is not working.
When I go to linked element option, it shows me the drop down window but no fields are listed. Hence I cannot link anything in linked element option.
13 Jun 2017 16:19 #2 by krowry
Hello ,
1) Check for errors logged in projeqtor log file
2) any error on browser console ?
13 Jun 2017 19:11 #3 by harish2181
Hi I have verified in log, it is showing as deliverables.php not found with below error message.
2017-06-13 18:35:55.598 ***** ERROR ***** Impossible to load class Deliverable
=> Not found in ../model/custom/Deliverable.php
=> Not found in ../model/Deliverable.php
=> Not found in ../model/persistence/Deliverable.php
Also if I am trying to include this file, projeQtOr stops working and shows blank screen.
15 Jun 2017 14:33 #4 by krowry
Version 6.0.0 are a version not stable , please install last stable version of the 6.0 ( it's version 6.0.8 ) .
This error come from your install. In your database , check if , in table "Linkable" , you have "Deliverable" and/or "Incoming" . If you have "Deliverable" or "Incoming' , delete this two elements.
16 Jun 2017 09:48 #5 by Optimist
It's working fine now. Thanks!!!
