ProjeQtOr free project management software - Problem with french translation plugin - Page 2 - ProjeQtOr
29 Mar 2017 17:15 #7 by AnthonyB
Ok, i will try this.
I can't actualy go in User parameters menu cause of message "ERROR : An error occurred on 2017-03-29 at 17:10:19". (same on global parameters menu)
Maybe can you help me here or i have to open a new topic ?
29 Mar 2017 17:23 #8 by babynus
post log file
29 Mar 2017 17:45 #9 by AnthonyB
File Attachment:
File Name: projeqtor_...0329.log
File Size:24 KB
29 Mar 2017 17:59 #10 by babynus
You are using PHP 7.1
ProjeQtOr, like many other PHP applications;, is not compatible with PHP 7.1
29 Mar 2017 18:18 #11 by AnthonyB
The required components and their versions are:
Apache V2 or higher (latest stable version recommended)
MySQL V5 or higher (latest stable version recommended)
or PostgreSQL : V9.1 or greater required (latest stable recommended)
PHP: V5.2 or higher required. > So wich version of PHP do you recommand ?
29 Mar 2017 18:35 #12 by babynus
PHP 5.6 or 7.0
but not V7.1 : it is quite new and brings severe regressions.
Many applications are not compatible with PHP 7.1.
For instance, PHP framework symphony (one of the most used) is not compatible with PH 7.1.
