ProjeQtOr free project management software - Cannot deleted ressource assigned in projet and delete project with 0 hours - Page 2 - ProjeQtOr
20 Mar 2017 22:58 - 20 Mar 2017 23:00 #7 by chriscool
help
How can we do that to clarify that?
Why the administrator profile can not delete assignments on the project?
I can not delete the project because it can not delete those assignments that have no imputation
i just can update right for each resources but not delete
thanks you by advance
Last edit: 20 Mar 2017 23:00 by chriscool.
22 Mar 2017 14:45 #8 by babynus
And in Specific acces rights ?
Did you change something on rights to change assignments ?
(please show print screen)
26 Mar 2017 11:57 - 26 Mar 2017 11:57 #9 by chriscool
hi
maybe i select yes "force delete"
see capture
Last edit: 26 Mar 2017 11:57 by chriscool.
26 Mar 2017 14:08 #10 by babynus
Can you show allocation to project list, and precise with wi=hich user you are connected when deleting item.
Because if you are allocated to the project with less rights (as project member for instance), this removes to you some access rights, even if you are an admin as default profile.
This can also be inherited from parent project.
28 Mar 2017 19:50 #11 by chriscool
hi
Yes I suspect, but I just use the admin account directly!
Even as a christian or I have added as administrator, I can not delete any resources from the project and thus delete this project
Same problem with another project or there is no time listed
We have only transferred the project activities to another project
29 Mar 2017 17:02 #12 by babynus
Can you try and delete allocation from Resource screen or from allocation screen (second is best as it could give hints)
