ProjeQtOr free project management software - Problems downloading versions - ProjeQtOr
13 Mar 2017 17:02 #1 by acalderon
Hi.
I need to download between the latest stable versions.
Every time I try to download a version it takes me to the sourforge page.
When starting the download of the .zip and trying to decompress it gives me an error.
Thank you,
14 Mar 2017 00:01 #2 by babynus
Download on sourceforge is normal.
Which version do you download ?
And what is the error you get ?
14 Mar 2017 14:30 #3 by acalderon
When I unzip the .zip, it appears to me:
An error occurred: activate the option "Store the output of the compression program"
Active output however does not show me the (.zip) files in the .zip folder
The system we are using is debian
Thank you
14 Mar 2017 14:42 #4 by acalderon
I downloaded several versions with the same result
14 Mar 2017 20:05 #5 by babynus
I think you should upgrade your zip programm.
Unziping on debian like distro works fine...
Or possibly it is due to the way you copy the zip file to your server : if you copy in text mode you'll have issues, always copy zip in binary mode.
16 Mar 2017 14:50 #6 by acalderon
Good morning, I will perform the tests with your indications.
Thankful for the information.
