ProjeQtOr free project management software - [SOLVED] Management of route sheets and production - ProjeQtOr
21 Feb 2017 14:06 #1 by mikael.bockstal@etia.fr
Dear all,
I would like to know if ProjeQtor is able to manage production with route sheets. I explain.
I have to sell finished product FP. This product is made with several raw products (could be semi-finished too). Lets say 2 raw products A and B. A is a packaging managed per unit in stock and B is a liquid product.
So, for the example : 1 x FP = 1 x A + 20 ml x B
Is there a possibility in ProjeQtor to manage this with provisional raw material management according to quotations and order book ?
In addition, Is there a possibility to add a cost (standard and then real after manufacturing) to each step of manufacturing, and maybe possibility to declare quality losses ? (labour and machine/energy costs, non quality) so as to obtain cost of products ?
Thank you for your help,
Best Regards,
Mikaël
25 Feb 2017 13:49 #2 by babynus
Maybe you can manage to have ProjeQtOr fit your need, but its is not a Production Management System.
It is a Project Management tool.
So you need to define a Project with correspondiong constraints (see Wikipedia definition of a Project, I like it) : an objective, defined number of activities, defined start and end dates, budget.
28 Feb 2017 15:10 #3 by mikael.bockstal@etia.fr
Thank you for your answer. I understand that ProjeQtor is not a Production Management system. So it will not fit to my colleague needs.
