ProjeQtOr free project management software - [SOLVED] Installation connexion bdd mysql par socket et non par ports - ProjeQtOr
20 Feb 2017 12:11 #1 by ARSGEDT088
Bonjour
Est il possible de configurer l'accès à la BDD MySQL avec un accès par socket et non par ports , le fichier de configuration le refuse
20 Feb 2017 12:13 #2 by babynus
Please post your questions in english.
20 Feb 2017 14:15 #3 by ARSGEDT088
Sorry
I'll like to connect to my database using MySQL socket instead using port . How Can I do it
20 Feb 2017 15:08 #4 by babynus
No, it's not possible to use socket.
If you need a secured connection, you can use SSL connection to MySql (look at last parameters in Global Parameters screen).
