ProjeQtOr free project management software - Project Types (OPE, ADM, TMP) - ProjeQtOr
20 Feb 2017 08:32 #1 by Öz
Hi everyone,
What are the differences of OPE, ADM and TMP project types? I read the user guide. But it's not detailed and it didn't help me.
20 Feb 2017 08:58 #2 by babynus
ADM = Administrative
TMP = Template
These two cannot be changed nor removed (you can only rename them)
OPE = Operational = all other project types, that you may define on your own.
20 Feb 2017 09:14 #3 by Öz
Replied by Öz on topic Project Types (OPE, ADM, TMP)
Thank you for your reply babynus.
Yes, I read them but where can we use the ADM and TMP project types?
In user guide for ADM:
"Type of project to follow non productive work : holidays, sickness, training, …"
How they can be projects? Surely, I skip something with that.
In user guide for TMP:
"These projects will not be used to follow "some" work.
They are just designed to define templates, to be "copied" as operational projects."
If the TMP project types use just copy, why writes "some". So In projects, can we follow the some works with TMP project types?
20 Feb 2017 09:36 #4 by babynus
Project Type is used on ... Project.
Activity Type is used on ... Activity.
Ticket Type is used on ... Ticket.
20 Feb 2017 09:40 #5 by Öz
It's not my question.
23 Feb 2017 23:52 #6 by babynus
They are not really project, but object Project is used to follow such non productive work.
You should read "These projects will not be used to follow any work.
