ProjeQtOr free project management software - error in historic display - ProjeQtOr
19 Feb 2017 11:22 #1 by Mike007
hi,
all updates made on user's projects are displayed on another user
is it a bug?
thanks.
french version:
il a été constaté que d'anciennes mises à jour apparaissent sur l'historique avec un autre compte (utilisateur) autre que celui qui les a faites.
est -ce un bug?
Merci
20 Feb 2017 09:06 #2 by babynus
Replied by babynus on topic error in historic display
This seems really weird as this feature exists for long and has not been changes.
Could you check data in table history : is the cange correctly stores (witrh id of correct user) ?
20 Feb 2017 10:11 #3 by Mike007
Replied by Mike007 on topic error in historic display
hi,
The updates displayed in the history panel are also displayed in Report -> Detail History of an item
so these updates are saved in the table.
thanks
20 Feb 2017 11:36 #4 by babynus
Sure they are saved, but I would like to know if it's saved with correct idUser (and displayed incorrectly) or saved with wrong idUser.
21 Feb 2017 11:35 #5 by Mike007
hi,
We checked in the history table and actually the id is that of the user who appears on the poster of the history (so it's a bug).
thanks
26 Feb 2017 11:00 #6 by Mike007
hi,
The history problem still persists, there are other updates that appear again but with another user.
thanks.
