ProjeQtOr free project management software - dates des versions de produits non retournées au niveau du projet - Page 2 - ProjeQtOr
17 Feb 2017 08:13 #7 by ashofphoenix
babynus wrote:
However, as soon as i fill a end date of the version (so a closed status of this version), all dates filled in the linked project (start/stop/closed) dissapear ! Why ?.
There is no automatism to work this way.
So I think it may be due to other side, possibly planning calculation?
There is no automatism to maage project dates from version dates or reverse bahavior.
Well i didn't have any planning for that project atm. I just wanted to prepare the project with past product version history.
But as I said as soon as I put an end date to the product version, the date into the linked project just erased... :/
hum...
Gonna try to update to last stable version .. (sure you understodd I was using 6.0.2 version ;)
17 Feb 2017 09:13 - 17 Feb 2017 09:19 #8 by ashofphoenix
I've updated Projeqtor to V6.1.0
Same result
See attachment to see what I'm talking about...
product_version tab with project section START/STOP/CLOSED ok but with no END DATE for product_version > This appears as expected into "project tab >all versions product section"
as soon as I closed the product_version in the product_version tab, the "product_version tab > project section" is cleared, and so is the "project tab > all versions product section"
Last edit: 17 Feb 2017 09:19 by ashofphoenix.
17 Feb 2017 16:10 - 17 Feb 2017 16:41 #9 by babynus
OK, I better understand now....
First there may be a misunderstanding : on the productveriosn / project relationship, start and end dates have no link to version dates.
These are the dates of the validity of the relationship (it was designed this way to temporally fix duration of the relationship but theses dates are not used)
Then, the changes you face are due to link from Project to Product. This link just defines a relationship that will generate relationship for all versions of the product.
So dates for relation between Project and Product are copied to Product Version / Project relationship....
There way be an issue as these dates are not propagated on creation of the relation, but when updating product version...
We'll record a ticket to see what can be done to improve this behavior :
- remove start-end dates (as they have no major interest as of today)
- propagate project-product relation dates every time (fix missing behavior)
- never propagate project-product dates (except maybe on creation) to remove this maybe uexpected behavior.
Edit : Ticket #2559 recorded
Last edit: 17 Feb 2017 16:41 by babynus.
21 Feb 2017 08:24 - 21 Feb 2017 08:26 #10 by ashofphoenix
babynus wrote: OK, I better understand now....
Thx for your reactive action. Yes, obviously it's important to keep history of project/product version relationship :)
If I understood what you said, those relationships could be in the 'near future' only "editable" and visible 'only' on the project tab, where all version of the product are listed and when the relationship is declared ? That should be great.
However and just in my opinion, I find it also very confortable to have a "reminder" of the projet / product version relationship on the product version tab, even if it should be only readable and could be only modified on the project tab, you will directly see that this product version was (or is still in) used but this, this or this project from X to Y date.
Will this specific project/product relationship be 'warned' or "closed" at the project level when the specific product version has an ENDED date or CLOSED ?
Last edit: 21 Feb 2017 08:26 by ashofphoenix.
25 Feb 2017 02:01 #11 by babynus
Not in the near future, it alredy rexists. But will not be the only way. Project-Version relationship will still exist.
No, as relationshi^p may be still valid for existing or future versions.
Time to create page: 0.061 seconds
