ProjeQtOr free project management software - [SOLVED] S curve Planned value not egual to project estimates - ProjeQtOr
11 Feb 2017 15:56 #1 by mcambron@videotron.ca
I have a mini project with about 10 task and 207 assigned hours ( seee screen capture) and when i produce the S curve , I see only 29 hours for the coût budgetiser du travail planifié (see s curve figure). Shouldn`t the 207 assigned hours be equal to the planned value ( coût budgetiser du travail planifié)? Am I missing something?
11 Feb 2017 16:39 #2 by babynus
Mayby a conversion issue.
It seems S-curve is displayed in days but unit displays "h" for hours.
Can you confirm that it is correct if unit is not jours but days ?
11 Feb 2017 16:58 #3 by mcambron@videotron.ca
It does not seem to be a conversion issue since 207 assigned hours represents 25.8 days of effort ( at 8 hours per day) and the S curve displays 30 hours of planned work.
Would you have any suggestions?
Regrads
Thank for your support
12 Feb 2017 18:26 #4 by mcambron@videotron.ca
To complement the issue, the hours on burn down chart seem to be correct.
Michel
20 Feb 2017 15:39 #5 by mcambron@videotron.ca
Hello Babynus,
Have you had the time to investigate the problem? I have added notes to my discussion on the forum and I am not shure you have received them.
Thank you in advance for your support
24 Feb 2017 21:06 #6 by babynus
Issue is fixed on V6.1.1,
and it is (as I guessed) a conversion issue : days were displayed with unit showing hours
