ProjeQtOr free project management software - [SOLVED] Since upgrade to 6.0.5 not able to save any data. Always gets Technical Error - Page 4 - ProjeQtOr
30 Jan 2017 07:40 #19 by iconic
I am 100% sure that no one changed code and unzipping was done on server so there should not be any mistake.
30 Jan 2017 09:13 #20 by babynus
Can you please search for existing ActivityMain.php file in whole project structure.
Where do you find it ?
Also show definition of function getStaticColCaptionTransposition() in files
=> /model/ActivityMain.php
=> /model/persistence/SqlElement.php
What is you version of PHP ?
31 Jan 2017 04:29 #21 by iconic
I can see two ActivityMain.php files.
1. /model/ActivityMain.php
2. /model/custom/ActivityMain.php
protected function getStaticColCaptionTransposition($fld=null) {
return self::$_colCaptionTransposition;
protected function getStaticColCaptionTransposition($fld) {
/model/persistance/SqlElement.php
return array();
Installed php version is 5.6
31 Jan 2017 08:31 #22 by babynus
/model/custom/ActivityMain.php is not part of ProjeQtOr.
Maby you copied it for tests.
There should never be any XxxxMain.php in /model/custom.
Just remove it.
01 Feb 2017 05:23 - 01 Feb 2017 05:27 #23 by iconic
I removed the file mentioned by you. Now it logs me in and show all activities and all details however, whenever I try to save anything I get following error.
Technical issue occured possibly due to bad network connection.
Please try again.
If issue persists, please contact your administrator.
Contact your administrator.
Also when i try to add any note it shows following error.
ERROR : noteRefType parameter not found in REQUEST
Last edit: 01 Feb 2017 05:27 by iconic. Reason: Added extra information
01 Feb 2017 09:38 #24 by babynus
First be sure to clean browser cache.
Then, report any erro reported in projeqtor log file, in apache error log file oir in browser console.
