ProjeQtOr free project management software - [SOLVED] Email feature is not working Kindly help - ProjeQtOr
19 Jan 2017 16:02 - 19 Jan 2017 16:08 #1 by rakesh4java
Hi ,
Email Feature is not working.
Projeqtor log file (projeqtor_20170119.log)
2017-01-19 19:50:26.683 ***** ERROR ***** ERROR *****
2017-01-19 19:50:26.685 ***** ERROR ***** on file 'C:\inetpub\wwwroot\projeqtor\external\PHPMailer\class.smtp.php' at line (981)
2017-01-19 19:50:26.686 ***** ERROR ***** cause = fwrite(): send of 6 bytes failed with errno=10054 An existing connection was forcibly closed by the remote host.
2017-01-19 19:43:29.171 ***** ERROR ***** Error sending mail
2017-01-19 19:43:29.172 ***** ERROR ***** SMTP Server : XX.X.X.XX
2017-01-19 19:43:29.174 ***** ERROR ***** SMTP Port : 25
2017-01-19 19:43:29.175 ***** ERROR ***** Mail stored in Database : #89
2017-01-19 19:43:29.177 ***** ERROR ***** PHPMail error : SMTP connect() failed. github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
2017-01-19 19:43:29.179 ***** ERROR ***** PHPMail debug :
(Note Actual IP Address was used)
Environment Details:-
Projeqtor version is V6.0.4 (155)
Dojo 1.10.6 (718461a)
App Server : IIS
PHP Details :-
PHP Version : 5.6.28
Compiler MSVC11 (Visual C++ 2012)
Architecture x86
Server API CGI/FastCGI
PHP API 20131106
PHP Extension 20131226
Zend Extension 220131226
Zend Extension Build API220131226,TS,VC11
PHP Extension Build API20131226,TS,VC11
Registered PHP Streams php, file, glob, data, http, ftp, zip, compress.zlib, https, ftps, phar
Registered Stream Socket Transports tcp, udp, ssl, sslv3, tls, tlsv1.0, tlsv1.1, tlsv1.2
SMTP smtpm02.org.com
smtp_port 25
Can you please help in this regard...?
Needless to say:- Thanks for the Coolest project.
Last edit: 19 Jan 2017 16:08 by rakesh4java. Reason: additional information added
19 Jan 2017 16:09 #2 by babynus
It is an issue to connect to your smtp server.
Mybe it requires authenticated connection or access through SSL ou TLS (then port should not be 25)
Check with your smtp provider
19 Jan 2017 16:25 - 19 Jan 2017 16:41 #3 by rakesh4java
Below test page works well:-
<?php
         $to = "rakesh1084@gmail.com";
         $subject = "This is subject";
         $message = "<b>This is HTML message.</b>";
         $message .= "<h1>This is headline.</h1>";
         $header = "From:rakesh1084@gmail.com \r\n";
         $header .= "Cc:rakesh1084@gmail.com \r\n";
         $header .= "MIME-Version: 1.0\r\n";
         $header .= "Content-type: text/html\r\n";
         $retval = mail ($to,$subject,$message,$header);
         if( $retval == true ) {
            echo "Message sent successfully...";
         }else {
            echo "Message could not be sent...";
Note: since php.ini is configured with smtp is configured above code is working.
Can you help:-
Last edit: 19 Jan 2017 16:41 by rakesh4java. Reason: additional information added along with image
19 Jan 2017 16:40 #4 by babynus
I this works, just set smtp server to localhost.
19 Jan 2017 16:42 - 19 Jan 2017 16:44 #5 by rakesh4java
Tried as per your suggestions:-
Changed to localhost
2017-01-19 21:12:27.980 ***** ERROR ***** ERROR *****
2017-01-19 21:12:27.983 ***** ERROR ***** on file 'C:\inetpub\wwwroot\projeqtor\external\PHPMailer\class.smtp.php' at line (286)
2017-01-19 21:12:27.986 ***** ERROR ***** cause = stream_socket_client(): unable to connect to localhost:25 (No connection could be made because the target machine actively refused it.
2017-01-19 21:12:27.988 ***** ERROR ***** Error sending mail
2017-01-19 21:12:27.991 ***** ERROR *****    SMTP Server : localhost
2017-01-19 21:12:27.993 ***** ERROR *****    SMTP Port : 25
2017-01-19 21:12:27.996 ***** ERROR *****    Mail stored in Database : #93
2017-01-19 21:12:27.998 ***** ERROR *****    PHPMail error : SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
2017-01-19 21:12:28.000 ***** ERROR *****    PHPMail debug :
Additional Information:-
have mantisBT also setup in place.
$g_phpMailer_method = PHPMAILER_METHOD_SMTP;
$g_smtp_host = 'sm02.org.com';
$g_smtp_port = 25;
$g_smtp_username = 'userid';
$g_smtp_password = 'secret';
$g_enable_email_notification='ON';
it is working.
have kanboard also in place where emails are working:-
// Mail transport available: "smtp", "sendmail", "mail" (PHP mail function), "postmark", "mailgun", "sendgrid"
define('MAIL_TRANSPORT', 'smtp');
// SMTP configuration to use when the "smtp" transport is chosen
define('MAIL_SMTP_HOSTNAME', 'sm02.org.com');
define('MAIL_SMTP_PORT', 25);
define('MAIL_SMTP_USERNAME', 'userid');
define('MAIL_SMTP_PASSWORD', 'secret);
define('MAIL_SMTP_ENCRYPTION', null); // Valid values are "null", "ssl" or "tls"
What could be the reason..?
Last edit: 19 Jan 2017 16:44 by rakesh4java. Reason: additional information added
20 Jan 2017 09:15 #6 by babynus
All should work fine with same parameters as for Mantis.
But we use phpMailer and I think that for authenticated connection (when user/password is provided) it automatically switched to secured connection (ssl I guess) to avoid to transfer login data unencrypted.
Possibly you can try to define
$paramMailerType='mail';
in your file parameters.php.
This will switch to standard php mail feature (less secured)
The following user(s) said Thank You: rakesh4java
