ProjeQtOr free project management software - Fields like "Description", "Compte-rendu", are not displayed with Edge browser - ProjeQtOr
19 Jan 2017 08:51 - 19 Jan 2017 08:53 #1 by dnaton
I have a strange behavoir when I use Edge browser (I'm on Windows 10). ((Microsoft Edge 38.14393.0.0 - Microsoft EdgeHTML 14.14393)
All the filelds like "Description", Objectif, compte-rendu,.....in meeting, activity, ticket, project, risqk,.... are not displayed.
If I use IE, Firefox, Opera, I don't have this problem.
Is there anybody who can reproduce my problem on a such configuration ? Or am I alone ?
Damien
Last edit: 19 Jan 2017 08:53 by dnaton.
19 Jan 2017 09:01 #2 by babynus
I don't reproduce this issue.
Text editors are correctly displayed on Edge, like on other browsers.
Can you check for errors in browser console ?
Can you also try and disabel / uninstall all extensions on the browser ?
19 Jan 2017 09:31 #3 by dnaton
Hello Babynus,
It was a good indication : the problem come from the plugin "AdBlock", since its last update (nothing happened before).
I added an exclusion for the url I use for ProjeQtor and all seems to be correct now (I continue some tests to see).
Thanks a lot
Damien
19 Jan 2017 09:34 #4 by krowry
Great Dnaton you found the solution of your problem ! Now you can try to do the same thing in Opera for your problem in the post "Issue on the view Planning" !
19 Jan 2017 11:20 #5 by dnaton
Hello Krowry,
unfortunately, it doesn't work with Opera : I disable all my plugin (only 2) but he problem is already present :(
I update my post withe the news informations
Damien
