ProjeQtOr free project management software - Plugin installation on fresh v6.0.5/ubuntu 16.04 - ProjeQtOr
11 Jan 2017 12:48 #1 by service_informatique
When i try to install translationFrench_V1.2 on fresh v6.0.5/ubuntu 16.04 lts, i have an error.
I found in the log file :
2017-01-11 12:34:51.485 ===== TRACE ===== New plugin found : translationFrench_V1.2.zip
2017-01-11 12:34:51.485 ***** ERROR ***** Impossible to load class ZipArchive<br/> => Not found in ../model/custom/ZipArchive.php <br/> => Not found in ../model/ZipArchive.php <br/> => Not found in ../model/persistence/ZipArchive.php <br/>
2017-01-11 12:34:51.486 ***** ERROR ***** EXCEPTION *****
2017-01-11 12:34:51.486 ***** ERROR ***** on file '/var/www/html/projeqtor/model/Plugin.php' at line (64)
2017-01-11 12:34:51.486 ***** ERROR ***** cause = Class 'ZipArchive' not found
2017-01-11 12:34:51.486 ***** ERROR ***** => #0 /var/www/html/projeqtor/plugin/loadPlugin.php (53) -> load()
An idea ?
11 Jan 2017 20:03 #2 by babynus
You must install (or just enable) zip extension on you php server
12 Jan 2017 10:25 #3 by service_informatique
Ok, it's solved.
Thank you.
