ProjeQtOr free project management software - Issue on the view "planning - ProjeQtOr
10 Jan 2017 09:37 #1 by dnaton
I remark since a few days (maybe since update to v6.0.5 but I'm not sure) that I have an issue in the screen "Planning", in all my projects :
The "gantt display" on the right on the screen works fine at the beginning, and is "synchronized with task on the left of the screen.
And suddenly, there is a misalignment between task and gant :(
Here is an exemple
How is it possible to correct the problem ?
Damien
10 Jan 2017 22:16 #2 by babynus
Replied by babynus on topic Issue on the view "planning
Can you check browser console for errors ?
Can you also check on other browser ?
12 Jan 2017 15:44 - 12 Jan 2017 15:45 #3 by dnaton
Replied by dnaton on topic Issue on the view "planning
Hello Babynus
I have tested with several browsers (Opera, Firefox, IE and Edge, last version in each cases) : the problem occurs only with Opera but is recent (I use Opera since a few month without any problem detected withe the gantt veiw)
I don't have Chrome installed on my PC
Nothing appears in the console and log.
Damien
Last edit: 12 Jan 2017 15:45 by dnaton.
14 Jan 2017 18:27 #4 by babynus
Issue recorded as Ticket #2499.
Will not be managed as Urgent as it only concerns one browser, not part of "most used" brwsers.
16 Jan 2017 15:51 - 16 Jan 2017 17:33 #5 by krowry
Replied by krowry on topic Issue on the view "planning
Hello Dnaton ,
I can't reproduce your problem . I use Opera 42.0 with Windows 10 and everything work's well .
Can you give me your version of Opera and what OS you use ?
Last edit: 16 Jan 2017 17:33 by babynus.
17 Jan 2017 12:02 - 17 Jan 2017 12:04 #6 by dnaton
Hello krowry
Her the informations requested
  • Opera 42.0.2393.94
  • Windows 10 Enterprise
  • Projeqtor 6.0.5
Strange,you can't reproduce this problem : I have it on all my projects, but only on Opera :unsure:
I will try to test on version before 6.0.5 and/or without plugins installed (Screencustomization and personalizedTranslations : symptoms are maybe differents.
Damien
Last edit: 17 Jan 2017 12:04 by dnaton.
