ProjeQtOr free project management software - Attachments not visible in my projects ? - ProjeQtOr
22 Dec 2016 19:42 #1 by chriscool
hello see my capture
i can't attach any document or hyperlink
why ?
on demo projeqtor i can
22 Dec 2016 20:09 #2 by babynus
This does not seem normal.
Dio you have any error in log file or in browser console or in Apache error file ?
23 Dec 2016 08:41 - 23 Dec 2016 09:13 #3 by chriscool
no error !!
same with anoter fresh install on 5X
there are feature to enable this ?
no error httpd
juste log file projeqtor
2016-12-23 09:11:34.407 ===== TRACE ===== ERROR - check Cron::Import() - is not a directory
Last edit: 23 Dec 2016 09:13 by chriscool.
23 Dec 2016 10:28 #4 by babynus
Your parameter "Attachment max size" is not set.
This simply disables attachment feature (not only for projets, but for all items).
Just set the value to max size of uploadable files.
Size is in Bytes.
For instance 10485760 for 10MB
23 Dec 2016 16:16 #5 by chriscool
yes it's good
easy resolve
thansk you !
