ProjeQtOr free project management software - Project affectation ressource by profil - ProjeQtOr
07 Dec 2016 18:14 #1 by chriscool
Still me, one thing I do not understand
I'm logged in with admin
I want to assign a resource to a project and choosing its profile I do not have the visu of the custom profiles (I closed the other profiles system)
With a user account, I have the visu of all the profiles
See the capture !!!
Thank you for your help and understanding in advance
08 Dec 2016 09:43 #2 by climb4fun
Hi Chris,
what's user profil of this user? If he is administrator, then it's clear.
Else check access rights of your granted profiles - there might be the root cause.
Klaus
08 Dec 2016 09:46 #3 by chriscool
The one with whom it does not work!
You do not see all the profiles is with the ADMIN account
I view all profiles with a second account TEST Member Project Manager.
Si with admin i can't show every project profil assign ?!
08 Dec 2016 12:00 #4 by climb4fun
I meant the profile of user in user profile - not in affection.
08 Dec 2016 12:17 #5 by chriscool
hi
show the user Admin Profil !!
And with this account i can't affect my custom profil to project
08 Dec 2016 12:35 #6 by climb4fun
Ah, your incident is not as I thought. Just to recap, what I understood:
1. You have created new profiles.
2. You have a project which is in progress.
3. You have a user, which is a resource.
4. You would like to assign/afect the resource to the project with the new created profile.
5. in the affection window you didn't find the new profile.
Correct?
