ProjeQtOr free project management software - [SOLVED] Numeric (decimal) format for Spanish - ProjeQtOr
05 Dec 2016 19:11 #1 by ico
Usually, in Spain,a colon is used as a decimal separator,but in latinamerca a dot is used a decimal separator.
Spain: 123,00
LA: 123.00
Projeqtor is using a colon as a default decimal separator. Is any way to especify which decimal separator ProjeQtOr should use?
Thank you
05 Dec 2016 19:41 #2 by babynus
ProjeQtOr will automatically adapt number formating according to brwoser configuration.
The following user(s) said Thank You: ico
05 Dec 2016 20:43 #3 by ico
Thank you, Im using Firefox and its configured to use "Mexican Spanish"; also winodws configuration is set to use $1,000.00 format. Nevertheless ProjeQtOr is showing expenses as $1.000
I will look to solve it through the browser configuration.
06 Dec 2016 13:37 #4 by climb4fun
Hi Ico,
a 2nd hint: give a look at local parameters of your server operating environment.
Klaus
