ProjeQtOr free project management software - Ligne "charge" not visible for profile "external project manager" - ProjeQtOr
14 Nov 2016 01:48 #1 by phil-bzh
What can I do to make visible the line "charge" for the profile "external project manager" ?
Thank you.
Bonjour,
Comment faire pour que les ressources associées au profil "chef de projet externe" voient la ligne "charge" dans les assignations ? Voir le assigné, le réel, etc. mais sans le modifier.
Merci.
14 Nov 2016 08:02 #2 by babynus
Update rights in Specific Access Rights
14 Nov 2016 19:50 #3 by phil-bzh
Hello babynus,
Thank you for your answer.
I did go to Parameters / Access rights / Specific access, and I've chosen work visibility = all visible and view assignments = yes
And in the block "Progress" of the actvities there is still no line "work :" between line "duration :" and line "progress :"
Maybe I must modify another value ?
Phil.
15 Nov 2016 07:07 - 15 Nov 2016 07:07 #4 by climb4fun
Hi Phil,
not clear if I understood you right.
In the line 'progress' there will be no line with work. It shows percentage of progress.
Work is displayed in the line 'work'.
May be a screenshot enlightens your issue.
Klaus
Last edit: 15 Nov 2016 07:07 by climb4fun.
15 Nov 2016 22:03 #5 by phil-bzh
My concern is the line "work :", not the line "progress :" => better with an image (see attached) :-)
On the right with profile Admin : the line work is visible :-)
On the left with profile "External project manager" : the line work is not visible :-(
Which right should I add in order to add visibility on the line "work :" (just visibility, not the right to change) for profile "External project manager" ?
Thank you !
(I changed the title : the english word for "charge" is "work")
16 Nov 2016 11:10 #6 by climb4fun
Hi Phil,
may I suggest to do following: see values in Access rights - Access to data (project related). For External team member should set adequate rights and it should work.
Klaus
